- Feb 8, 2014
- 11,144
Something like a corrosion inhibitor?
I'll need to do some research on this...
Automotive antifreeze
Interesting. I was thinking more like the water going rancid. Maybe that is not a thing though.I'm helping a guy on a different forum with a control panel design. He bought a $2000 ATC water cooled spindle from China and it recommended adding rust preventative to the cooling water to avoid damage to the spindle water channels over time.
I have an old colombo spindle (8HP, Air cooled, ceramic bearings). It is LOUD! Came from a signage shop. You could hear it a quarter mile away if they had the garage door open. The water cooled spindles are silent by comparison.Interesting. I was thinking more like the water going rancid. Maybe that is not a thing though.
The 10hp spindle (it is a beast) on the Shop Sabre that I play with occasionally is air cooled. If I decide to do this, that will be the route it take; the air cooling, not the 10hp!
Good to know. Thank you.I have an old colombo spindle (8HP, Air cooled, ceramic bearings). It is LOUD! Came from a signage shop. You could hear it a quarter mile away if they had the garage door open. The water cooled spindles are silent by comparison.
My build will only have a 2’x3’ footprint
I realize that your build is a 2x3 "footprint" but those rails are only 28.5" and 16" respectively.725mm HGR20 QTY (2)
425mm HGR20 QTY (2)
