- Jun 26, 2018
- 1,733
I hear ya, and that's why half of me is...."if it's not broke, don't fix it" but I would like some more torque...
Well I got everything wired up to test, and it seems that I must have blown another of those TI boards. I had it working with the display the other day (without the encoder or motor connected) and was super careful about static control (anti static mat/wristband, etc). I tested and retested every connection from the boards, through the connectors on my enclosure, to each device and all sounded out correctly. Long story short, I can't offer any insights into configuring the motor as I never got it to turn. It powered up fine, but the TI board seems dead - again. I swear, I have programmed and installed over a dozen arduinos and a few raspberry pi devices and have worked on countless PCs and never had this problem.
Funny, I put that in the comments of the Clearpath killer video...would he be doing a follow up video for all of us Clough ELS people that you KNOW are going to do this. This wasn't a walk in the park for me the 1st time. He something to the effect of, "it's a direct drop in/plug and play" Why did I feel like I'd be about 3 hours into it when I decided that wasn't the case.
So at the end of your install, what all did you have to do/change/alter? Did you have to get back into the driver to change anything? Did it come with it's own driver and does that use the same EDS software?
I'm not sure I understand the question, but the "Clearpath killer" servo has an integrated driver, a separate stepper driver is not needed or usable with this setup.Did you have to get back into the driver to change anything? Did it come with it's own driver and does that use the same EDS software?
Does it display the Clough42 and version number when you power it up on display? Or nothing? Those spring loaded connectors can be a pain to get a wire under them (better to use the crimp pins) but it won't fry the board.
I'm sitting here staring at a dead TI board. They seem to be fragile. I programmed one with the Clough software, no problem. The second board was dead. A third board works well.It displayed the Clough42 and version and functioned properly without the encoder or motor attached - and while outside the enclosure. I did use crimp pins all the way around except for the 8 pin "aviation" connectors for the connections through the enclosure. I had checked everything pretty carefully to ensure the connections were right - but I guess not carefully enough.
I had to step away for the evening as I was pretty steamed so I will get on it tomorrow and see if I can figure it out.
I don't feel so bad now. I have been buying them direct from TI - they have a rather odd ordering system that asks a LOT of odd questions but they do ship pretty quickly. My problem is that what should have cost about $35 is now going to be over $100 - and a bunch of lost time. They seem focused on whether I will use it in a military application or not - I sure hope the DOD is not buying these things because they seem pretty unreliable to me. I love James' system but if this keeps up I may look into one of the Arduino based control systems - those things are bullet proof ( at least comparatively).I'm sitting here staring at a dead TI board. They seem to be fragile. I programmed one with the Clough software, no problem. The second board was dead. A third board works well.
TI does not stand behind the product. After a week of going round and round with them, they agreed that the board was dead. Then said tough sh*t.
I hope that the working ones stay working.
