Finally got all the seals in for the carbs then spent a couple days getting the float valves to seal. THEN when putting the fuel banjos back in the correct position, I stripped a banjo bolt hole in the right carb. Inspecting the damage, it looks like a lot of the cheese metal in the threads had corroded away. Another bowl on order, it will be polished and placed on the center carb since the rest are chromed. This thing is so nasty - grease, oil, dirt all over it and the jugs/head painted with something that resembles truck bed liner. But with chromed carbs and rocker inspection covers. "Lipstick on a pig" indeed.
But other than slowly getting covers on with correct gaskets, that is about all of the progress lately. Spend a couple hours cleaning and trying to remove paint (at least from the head) then get frustrated and find something else to do.
Oh, and I found more RTV. The clutch pull rod seal was RTV'd in place, and as I tried to remove the old fiber sealing washer from the primary drain bolt, discovered it was actually RTV!
