- Jun 12, 2014
- 4,812
So a few things that I would recommend and some considerations for a 3 phase power source. My first recommendation for a turn key type of install would be an RPC for this size machine. You have plenty of mechanical gear speeds, the motor is extremely smooth and you have a mechanical brake that will quickly stop the lathe. You would need a 10Hp RPC. The American Rotary phase converter AMP is extremely quiet and you plug one end into the wall and the machines into the other end. The price has increased quite a bit from what I recall a year ago, but I the amp series is extremely quiet and a no brainier. Some recommendation below, most people buy the control box and find a 10Hp motor locally and save about 1K in the cost. eBay sometimes seems to have less expensive models, I do not have the time to sort through the models, I suggest you contact the companies directly to see what fits your needs. Also a number of Youtube posters have discount codes for American Rotary Phase products, so check them out you can usually save 5-10%. I think one was Vintage Machinery, Bar Z Industrial and there were a few others.
Panel
As far as VFD's it is not just a matter of purchasing one that has the proper capacities but also it is not plug and play, it needs to be integrated into a control system, programmed and the parameters adjusted for the particular unit in order for it to run correctly. You need to integrated the electronic braking with the mechanical brake. In most cases you would need a separate VFD enclosure and then integrate the VFD with the lathe, there are two approaches to this, first is to do what I call is a basic install which is what I have previously outlined for the 1440GT. The other alternative is a full system build that replaces all the machine electronics. At the end of the day, an RPC is about 1/2 the price and much simpler.
There are very few native 5 Hp VFD's, the only one that I know is the Yaskawa CIMR-VUBA0018FAA which has sufficient inputs and programming features for this application. I would skip the Chinese generic units that make all kinds of claims as to input/output, I have worked with a few of these and the input terminals and design does not support what they claim. Most people buy the next larger size to somewhat compensate for this, and then there is the manuals which are abysmal as well as no support. I have been involved with two builds for this line of lathes, the first one we went with an oversized Hitachi WJ200 3 phase input derated for either single or 3 phase input and the other was a Yaskawa V1000 which was also similarly derated. The models for this application would be the Hitachi WJ200-075LF, Yaskawa CIMR-VU2A0040FAA, which are 10Hp 3 phase input rated units. It is also recommended to use a DC choke to decrease the ripple and noise when used with single phase input. On these models I use the MTE DCA004003 (40A 1 mH), so between the VFD and choke you are pushing 1K, if you do a basic install add about another $500. Also since these are 10Hp VFD's they can draw very high instantaneous currents, as a minimum you would need a 50-60A 240VAC single phase input supply. This is also what you would need for a 10Hp RPC. The Yaskawa CIMR-VU2A0040FAA has a low enough profile that it should be able to fit into the stock machine cabinet with a full build but it is a complicated process, my recollection was the back plate needed to be cut out for the VFD to be mounted and clear the cover. The CIMR-VUBA0018FAA would need a separate enclosure but would not need a DC choke, since it is a native 5 Hp unit. FYI, on my ERL-1340 with a 3 HP motor I use the CIMR-VU2A0020FAA which is a 5Hp model, 3 phase input.
So it is all doable, but an RPC will be more practical to get you up and running with the least cost. As I mentioned, many individuals purchase the control panel and source an enclosed 1750 RPM motor locally.
AMP - Mobile Phase Converter - American Rotary
AMP Mobile - The AMP Mobile rotary phase converter is plug-and-play ready for a quick and cost-effective installation. Equipped to run 208-250V equipment in three tiers: Tier 1: 1 Breaker and 1 Receptacle Tier 2: 2 Breakers and 2 Receptacles Tier 3: 3 Breakers and 3 Receptacles These...
www.americanrotary.com
American Rotary Phase Converter AR10F Floor Unit 10 HP | Can start up to 5Hp | eBay
Single motor start: 5HP. Phase Converter ARF10 - 10 HP Pro Series. Plug N Play. Our variable impedance generator (VIT). Best for: 5 HP General Purpose, motor loads, combination loads, light to moderate loads.
www.ebay.com
PL-10 Pro-Line 10HP Rotary Phase Converter - Built-In Starter, Made In USA | eBay
10HP Pro-Line Rotary Phase Converter PL-10. Rotary Phase Converters. Static Phase Converters. Digital Phase Converters. Complete Phase Power Failure Protection. We have always specialized in the design and building of phase converters.
www.ebay.com
Rotary Phase Converter - 10 HP - CNC Grade, GP10P4LV | eBay
Sizing a Phase Converter. Select the appropriate phase converter. The Idler/ Generator is covered by the manufacture warranty for 2 years. Single Phase Electrical Specs. Horsepower: 10 hp. Three Phase Electrical Specs.
www.ebay.com
CP-10 Pro-Line 10HP Rotary Phase Converter Control Panel - Loaded with Features | eBay
Add your own 10HP electric motor to make a rotary phase converter. Your 10HP 3 phase electric motor as the idler motor. Rotary Phase Converters. Generator Type Your 10HP Electric Motor. Static Phase Converters.
www.ebay.com
Phase Converters NL - Single Phase 230V to Three Phase 230V
The most efficient & reliable 3 Phase Converters on the market. Shop single phase 230V to three phase 230V phase converters for sale online here.
www.phoenixphaseconverters.com
