- Aug 5, 2015
- 237
Sherline has a list of user submitted "Tips" that I find helpful.
I have recently used a couple of them. One is a simple lock for the Mill's Y axis (tip 28). The other is an adapter to use the Sherline lathe Compound Slide on the front side (tip 32). There are other Tips that are very interesting
This is the adapter I made. Ignore the brass screws please: I just haven't procured the right size steel screws. The unsharpened tool steel is just for reference. I made the adapter a bit longer than the Tip 32 shows and may cut it shorter after using it. The Tip doesn't give dimensions, so it is up to the individual how to make it.
Tips from Sherline Machinists – Sherline Products
www.sherline.com
