I have a gallon of Klean strip denatured alcohol. Since there is a run on hand sanitizer now,and this can be mixed with alovera gel. What would the alcohol percentage be for this type of mixture in the gallon? 60-70% is needed for the hand sanitizer. I'm having difficulty figuring out, here is the MSDS.
The name "Denatured Alcohol" means ethanol adulterated with methanol (aka wood alcohol), to make it not fit to drink, the intention originally being that ethanol as an industrial solvent that evaporated completely was just so useful, and cheap from industrial sources other than brewing, and associated tax arrangements. Perhaps the authorities expected the troops would take a tipple.
You can't distill it back to booze
Methanol CH3-OH, one carbon is very similar to ethanol C2H5-OH, the two-carbon booze alcohol. Together, they form a "
constant boiling point mixture". All you get is distilled pure mixture, perhaps with the color left behind. It won't separate.
Mostly purple - but can be clear.
Colored violet or purple except special sorts used in critical cleaning and some cosmetics. To let you know it is poison! Some will drink it anyway.
In bad taste!
The most bitter foulest tasting stuff that could be found is added. 10ppm is unbearably bitter to nearly all.
N-Benzyl-2-(2,6-dimethylanilino)-
N,
N-diethyl-2-oxoethan-1-aminium benzoate.
They call it "denatonium benzoate", a faked up name as if it was an element.
Used to deter nail-biting.
The actual stuff in it varies widely. Other solvents may be in the mix, like IPA, and methyl ethyl keytone. In USA, maybe up to 50% may be various stuff other than ethanol.
As a hand sanitizer.
Unlike proper hand sanitizer, the stuff does not have the added oils and moisturizers. IPA beyond about 70% will work as a hand sanitizer - but so will plain old soap. COVID-19 outer wall layer is like a grease that dissolves away in alkali, soaps, etc. and the virus collapses. There are some distillates from the Deep South, and no doubt other concoctions that are flammable, and will work.
About 2/3 down the page of a UK regulatory document gives the denatured alcohol recipe -->
HERE LINK
I can attest that drinking the mixture of ethanol, IPA, methanol and about 10% water was a bad experience!
https://www.hobby-machinist.com/threads/food-and-drink-in-the-work-area-ipa-ethanol-methanol.82740/
