- Sep 28, 2013
- 4,323
fixed a fix this weekend.
Added a piece of stainless wire to the aluminium freehub on my new wheels, so that the cassette gears wouldn't chew into the soft metal. Didn't work.
https://www.hobby-machinist.com/thr...-in-your-shop-today.67833/page-20#post-604495
So I made a bunch of inserts out of O1, hardened them and cut corresponding pockets in the freehub. Had a bit of a snafu when I realised that I was cutting into the freehub threads, so I had to modify the inserts. First time cutting hardened steel with carbide, went ok thankfully.
Cutting the first pocket with my soon to be deceased new end mill. You can see the wear on the next spline along.
Test fit after the pockets were finished. Did a bunch of grinding after this pic to match the curve of the freehub body so the cassette would slide on
Added a bit of cold blue after grinding and held the looser ones in place with a dab of superglue
All done
we'll see how they wear in the next 250 miles before a scheduled chain swap/ cassette clean
dead 2mm cobalt endmill. Only managed to cut 2 pockets before I got over enthusiastic with the slotting and it snapped Very sad..
All done
