Beautiful old American Iron and Steel
The guy who had it said 1800 lbs. The instructions said 3000 lbs. Probably crate plus accessories. Pretty heavy.
Those straps are going around smooth radius edges on the ways. Right now, I'm not being "that guy". Everybody can't wait to "gotcha' but there wasn't one.
Not the way I read the situation at all, but whatever.
I drained the oil and flushed the gearbox the best I could. The gears aren't pretty but the lathe is run-able. I had to fill a bit higher than the book said to get a certain set of gears to touch the oil to get half the gears to fully lubricate.
I adjusted one shaft so the gears would engage properly and the shift lever would lock in place properly.
I found out my lathe has a crude cone brake built into the clutch lever. Metal against metal. No idea if it had friction material or if it should be lubricated.
I don't think I'll be taking the monster cuts this lathe was designed for but it will still take much bigger cuts than the little Chinese 10x30 I have now.
I have not yet figured out how to control the feeds for standard turning.
