I've not used the eensy weensy driver boards like above. However it's pretty easy to find a tba6600 style driver boards for $10 that has screw terminals for wires. Much easier to use.
I like how cheap this stuff is.I've not used the eensy weensy driver boards like above. However it's pretty easy to find a tba6600 style driver boards for $10 that has screw terminals for wires. Much easier to use.
I didn’t find anything under your description, tba6600.I've not used the eensy weensy driver boards like above. However it's pretty easy to find a tba6600 style driver boards for $10 that has screw terminals for wires. Much easier to use.
Later on this morning I will find you the link. I found it on Amazon by searching for stepper motor driver. Last night it was listed at $9.95. The driver chip itself is a Toshiba TBA6600, I think. It's a lower end controller, but super easy to use for NEMA-17 and under steppers.I didn’t find anything under your description, tba6600.
Could you please point one out for me
Not quite, the unit I was looking at was up to 4A.I believe @WobblyHand is referring to a stepper dive such as this.
Digital Stepper Driver 0.3-2.2A 10-30VDC for Nema 8, 11, 14, 16, 17 Stepper Motor - DM320T|STEPPERONLINE
Digital Stepper Driver 0.3-2.2A 10-30VDC for Nema 8, 11, 14, 16, 17 Stepper Motor - DM320T - Open Loop Driver - This is a digital stepper drive implemented with advanced stepper control technology. It is easy to use and it can be used to drive 2-phase andwww.omc-stepperonline.com
StepperOnline is my go-to for low cost stepper products. They also have an Amazon and eBay store.
