- Dec 18, 2013
- 2,012
I know I've done my part!
DZ, Jim, Bill the axis of EVIL!!
Sure. No problem. The distance to the top of the cross slide that the compound sits on is 5.06". The slide for the compound is 1.78" higher than the top of the cross slide and the top surface of the compound is 3.36" higher than the top of the cross slide. So, that's 3.28" from center to the slide for the compound and 1.70" from center to the top surface of the compound. The top of the compound is 3.8" wide.
I don't have vast experience with a lathe. My experience is high school shop and my uncle let me use his from time to time, both decades ago. So, take my comments with that in mind. It was a tough decision about the lathe. I came close to getting a 4003g to save money and have a lighter weight lathe for ease of shipping etc. The 0509g just has more meat on it, wider ways etc. I thought it would be much stiffer and allow for more capability as my skills hopefully grow to catch up with the capability of the lathe. I have few complaints so far. Everything worked. All the parts were there. All of the gears worked. Some of the gear levers are touchy and you have to get them just right but they work. The manual is a little sketchy but not unusually so for any machine these days. Changing gears to go from worm to regular threading took a little time to figure out as the manual has just a couple of sentences and a bad photo. Still, it just took a few minutes and a "duh" moment to get it done.
I bought a motor-type phase converter that was too small for the job. I got a 7.5HP for the 5HP motor of the lathe. Had I been more careful, I would have read up and known better. These motors seem to take lots of start-up current. It did work on low gear/low speed settings but the spin-up time was slow. On high settings I would pop the overload or a breaker on the lathe. The inverter I have now is much better. The brake is very convenient. The machine is massive and takes a while to come to a stop without the brake.
Thanks a bunch Reddinr. So the spindle centerline is 1.70 inches from the top of the compound where the QCTP would sit. The "optimal" centerline for the Dorian CXA is 1.65 inches so the CXA is near perfect size for the G0509G. The working range for the CXA is 1.25 to 2.25 inches allowing plenty of room up and down for different tool heights. The Dorian CA is clearly too large with an optimal centerline height of 1.937 and range of 1.562 to 2.562.
I would be interested in any info you could share on your choice of inverter.
The G0509G uses a barrel switch to control SLOW vs FAST winding power. If you wired that directly to your VFD 3 phase output, you are trusting yourself not to goon things up by shifting the speed when the lathe motor is turning.I have read (don't know how accurate it is) that a problem with using a VFD for the G0509G is the main motor operates at 2 different speeds/windings then there is the 2nd 3 phase motor for the coolant pump.
