G0704 CNC Conversion (yes, another thread on this :) )
Making the 8 wire motor into a 4 wire and attaching to long cable
Done... so easy to get confuse with all the wire colors as you match to the cable... I used the diagram on the first page to convert from 8 wires to 4 wires Bipolar (Series) connection... Checked continuity for each set of coils and wire it up...
I have it all so that the pins on the connectors are:
Pin1: A+
Pin2: A-
Pin3: B-
Pin4: B+
Easier for me to then remember the wiring order from the connectors to the stepper drivers.
Maybe I should wait until the 4th of July to plug this in... you know, just in case there are fireworks when I do....
Only waiting for the safety relay and emergency stop switch to finish it... Will not deal with the C6 board and relay for the cooling/air nozzle until everything else is working...
Oh, and I need to read up on how I need to configure those dip switches in the stepper drivers...
Well... thinking of doing a test run without the safety relay in place...
What could go wrong, right?
I had the ethernet cable directly from the board to the computer for the initial tests.... but then connected that to the passthrough port to test that as well... All working as expected. I need to get a shorter ethernet cable to put inside the case. The one currently in there is too long...
Could not resist... had to give it a go....
Only question/concern that I have. Z-axis motor gets warm without using it. Is that normal? Did I wired something wrong? The X and Y 23 stay cool to the touch without activating them... the Z, without activating it, is warm to the touch...
Videos:
Manually controlling the motors
Running a demo program Mach4 had
On the Z-axis motor... I wonder if it has to do with dip switches configuration... but even with Mach4 turned off I can feel the motor... like it is humming... where the other two are completely off (or at least, I can't feel any vibration in them)...
I should be setting all dirvers to the same steps values, correct? X and Y are the same drivers, Z is a different driver...
I see that I now have them set differently (pin settings are the same, but being different drivers, they are set at different steps/rev settings...
Current with the way the photo above shows:
Z - SW5-On/SW6-On/SW7-On/SW8-Off = 1000 Steps/rev
X - SW5-Off/SW6-Off/SW7-On/SW8-On = 1600 Steps/rev
Y - SW5-Off/SW6-Off/SW7-On/SW8-On = 1600 Steps/rev
So I know that can be changed... but what should I change it to? All to 1000 Steps/rev? Or?
Also, current setting??? Currently, base on the photo shared:
Z - SW1-Off/SW2-On/SW3-On = Peak Current 6.1A / RMS 4.3A also SW4-Off meaning that the standstill curren is set to be half of the selected dynamic current... whatever that means.
X - SW1-Off/SW2-On/SW3-On = Peak Current 5.6A / RMS 4.0A also SW4-Off meaning that the standstill curren is set to be half of the selected dynamic current... whatever that means.
Y - SW1-Off/SW2-On/SW3-On = Peak Current 5.6A / RMS 4.0A also SW4-Off meaning that the standstill curren is set to be half of the selected dynamic current... whatever that means.
Guidance here would be extremely appreciated...
For now I just set them all to 1000 Steps/Rev
X - SW5-On/SW6-On/SW7-On/SW8-Off = 1000 Steps/rev
Y - SW5-On/SW6-On/SW7-On/SW8-Off = 1000 Steps/rev
On the vibration that I feel when the motor is idle... found and article.
"When stepper motors operate, they operate by drawing current continuously. This method of operation ensures more accurate positioning and more consistent torque. However, this also means an increase of energy they use and the amount of heat they produce. This holds true even when the stepper motor is idling."
So I am guessing that since it is always receiving current that explains the slight vibration at idle and the warm temperature.
My stepper driver has Automatic idle-current reduction set to off... so at idle it current should be reduced by 60%... I just do not get why the 23 motors do not display any vibration at idle and the 34 does... I am tempted on ordering a 4-wire 34 motor just to compare... I am trying to validate if this is related to my install/configuration or if it is normal
So there is more than just setting DIP switches... need the specs on the lead screws before I can determine those settings...
