On the Z-axis motor... I wonder if it has to do with dip switches configuration... but even with Mach4 turned off I can feel the motor... like it is humming... where the other two are completely off (or at least, I can't feel any vibration in them)...
I should be setting all dirvers to the same steps values, correct? X and Y are the same drivers, Z is a different driver...
I see that I now have them set differently (pin settings are the same, but being different drivers, they are set at different steps/rev settings...
Current with the way the photo above shows:
Z - SW5-On/SW6-On/SW7-On/SW8-Off = 1000 Steps/rev
X - SW5-Off/SW6-Off/SW7-On/SW8-On = 1600 Steps/rev
Y - SW5-Off/SW6-Off/SW7-On/SW8-On = 1600 Steps/rev
So I know that can be changed... but what should I change it to? All to 1000 Steps/rev? Or?
Also, current setting??? Currently, base on the photo shared:
Z - SW1-Off/SW2-On/SW3-On = Peak Current 6.1A / RMS 4.3A also SW4-Off meaning that the standstill curren is set to be half of the selected dynamic current... whatever that means.
X - SW1-Off/SW2-On/SW3-On = Peak Current 5.6A / RMS 4.0A also SW4-Off meaning that the standstill curren is set to be half of the selected dynamic current... whatever that means.
Y - SW1-Off/SW2-On/SW3-On = Peak Current 5.6A / RMS 4.0A also SW4-Off meaning that the standstill curren is set to be half of the selected dynamic current... whatever that means.
Guidance here would be extremely appreciated...
