- Feb 5, 2014
- 198
Redlineman,
The new nut fits great on the original shaft. I did notice more yaw & pitch motion when installing the shaft into the nut free than i thought i should have but the axial lash is gone. I used have probably .020" lash.
I did investigate what i would do if i had to replace the screw as well. Likely i was going to buy some left hand ACME threaded rod and splice it into the old shaft. Glad i did not have to tackle that.
As for the stripped hole. I here you. I went to get a longer bolt because there were a couple of good threads at the bottom of the hole but as soon as i engaged those threads they let go too. I likely will just buy the $12 tap....
Mr. Ed. Curse you. )
I found myself looking on Ebay this AM for a larger dial for the crossfeed. Now i am compelled to ask what you all have "upgraded to".
Matthew
Matthew
