- Apr 14, 2012
- 78
Re: Capacitor questions
Frank, you say that the capacitor is not in the circuit after the motor starts. Since my capacitors are tin cans, I thought they would be start and run capacitors. Also, I thought that we determined in the continuity tests that the capacitor was possibly not in the circuit at all or at least not in forward. When I started it up in forward and reverse and forward took longer to spool up, I thought that was an indication that forward did not have the capacitor in the circuit and reverse did.
Can you tell me again how to test the motor in high speed range without using the switch? Don't know if I can find it in the past posts. I will also test the lathe in high speed reverse to see if it seems to function normally (not the way forward functions). Jim
