- Aug 6, 2015
- 3,912
I would think you don't need the brake if you have the tool. It's doing the work for you. I could be wrong, but that's what I think.
I thought about that... then about machining the drawbar to correct length... then about making a shim to go between the Maxi Torque-Rite and the base plate to compensate for the raise the cartridge bearing locknut with the pulley shaft
But by then I was just too scare to tackle it all... Yeah, I am obviously missing an adapter...
